Sponsored by: CARiD
Pulled 8 codes!!
Old May 8, 2010 | 06:21 PM
mcalus's Avatar
Default Pulled 8 codes!!
P0160 -O2
P0160 -O2
P0140 -O2
P0140 -O2
P0405 -EGR
P0405-EGR
P0135 -O2 heather CKT malfunction
P0410 - SEC Air injec system malfunction
Ok so from what I understand, 5 of these codes can be tuned out. Since I just put LT's, ORY, and LS6 intake on. Which would be 2 of the O2 sensors (rears), the 2 EGR's and the AIR system one since I deleted all of these with the install.
Now I have been having a idle issue. When I first start the car it runs up to 2500 rpms. then once i start driving its fine tho the car likes to pull to about 2,000 rpms. The lets say I am going 55, in 5th gear, if I push the clutch in or put it in neutral the car revs up to 2-2500k. And it will stay that way until I come to a complete stop then it calms down after sitting for about 10 seconds to 12-1300k, which is still high.
Any suggestions on what is going on here? I I have checked everything for an intake leak. My next thing I can do is put the stock LS1 intake back on.
Am I just in real bad need of a tune?
Thank you!!!
Old May 9, 2010 | 09:19 AM
purple98haz28's Avatar
you may have a vacuum leak causing the revs up to 2500. more than likley thats it considering the mods you just did
Old May 9, 2010 | 10:06 AM
natejk's Avatar
sounds like you missed the skinny line next to the sesor on the back of your manifold i did the same plugged it back in ran like a dream
Old May 9, 2010 | 10:58 AM
mcalus's Avatar
I have checked everything other than the underside of the intake.
I dont think that is it cause my heat wouldnt work if that was the case.
Old May 10, 2010 | 07:14 PM
madeintheshade05's Avatar
if all lines are hooked up properly then maybe you do just need a tune. when my buddy had an ls6 intake installed he was tuned right away and he never had that problem so maybe try that.
Old May 10, 2010 | 09:16 PM
98pontiac's Avatar
tune them all out. Im assuming you put on headers, and did not hook everything back up properly. your in need of a tune.
Old May 12, 2010 | 02:23 PM
mcalus's Avatar
anyone heard anything about the $50 mail order that a sponser on here is running?
