Sponsored by: CARiD
2001 formula ls1 KNOCK SENSORS
Old 05-11-2010 | 09:48 AM
01formulals1's Avatar
Exclamation 2001 formula ls1 KNOCK SENSORS
HELP knock sensors came back up on the codes a week later after replacing them.. Car is running lean because of bad o2s could that be the setting off my knock sensors
Old 05-11-2010 | 02:36 PM
91RS383's Avatar
Knock sensors check for knock and ping.
If you are running lean, your cylinders overheat. This can cause the fuel to detonate prematurely. This detonation can definately be the cause of your knock.
Old 05-12-2010 | 12:06 PM
RARON455's Avatar
When you torqued the knock sensors down it should have only been to 11 ft. lbs, many people over tighten these and it causes all kinds of problems....
