Lean bank 1 and 2 codes (P0171, p0174)
What vacuum hoses do I have to unhook and where is the FPR to even check? And is there anyway to test the the regulator or pump before I take the tank out. It was always my understanding that a faulty fpr would cause a rich problem not a lean. Especially the pressure with a faulty afr would actually be higher then normal causing the rich condition.
