Sponsored by: CARiD
Driver side mirror housing
Old May 15, 2010 | 08:52 PM
blackbirdls1's Avatar
Default Driver side mirror housing
My drivers side mirror housing seems to be loose. Which bolts tighten this, I know there are 3 nuts when you remove the plastic piece from inside the car and there are 2 screws on the outside that seem impossible to get to.
Old May 16, 2010 | 06:57 PM
Bump, anyone have any experience with this?
Old May 16, 2010 | 07:00 PM
9911UZ28's Avatar
try this
Old May 16, 2010 | 08:26 PM
Ty, I will give it a shot
Old May 16, 2010 | 10:28 PM
peterlawl84's Avatar
Its held on by those 3 bolts you mentioned. My bracket snapped somehow while driving so I had to buy a new unit from the dealership...which sucked.
Old May 17, 2010 | 01:30 PM
Well I was able to tighten the 3 bolts somewhat, they didnt move much, and the housing still seems "loose".
Old May 17, 2010 | 02:02 PM
Pitbull329's Avatar
Your bracket is most likely cracked. Mine was loose as well for some time... then one day, the housing was just hanging on by the two bolts on the bottom of the bracket (cracked all the way through). I took the housing off, got JBweld and little pieces of metal. I put the little pieces of metal on both sides for extra strength. Put JB weld on both sides, let it dry for a few days (car was down for a few days because I got a mail order tune) and put it on. Now its pretty damn firm on there.
