Sponsored by: CARiD
Window motor help...
Old May 20, 2010 | 01:51 PM
01zb4c's Avatar
Default Window motor help...
I have a 00 camaro ss and the window motors are acting up... the drivers side is a new motor and works when it wants so i thought it was the connector... and the the pass side never wrked... so i bought a new motor today and went to install it, before i bolted it up i checked it, it will run when u press the button up but nothing when u want to go down, same as the old motor.. drivers side button for the pass side wont do anything.... any thoughts thanks...
Old May 20, 2010 | 10:10 PM
2kflhr's Avatar
Sounds like switch failure. Have you tried jumping out the terminals from the harness to bypass the switch(s) ?
Old May 20, 2010 | 11:07 PM
01zb4c's Avatar
My buddy had another switch and we changed them out and that fixed it... thanks for the help tho...
