hatch lid rattling
hatch lid rattling
does anyone else have this problem when i hit bumps my dam trunk lid is rattling and this is driving me crazy i check it all the time and it feels tight someone please give me some ideas?
Are the hatch struts both good? Is the hatch making contact with the adjustable rubber bumpstops? I think I have a little squeak coming from one of my struts, little things like that drive me crazy too.
check the tack welds on the hatch assembly. mine had broken welds at the bottom and it would rattle and squeak bigtime...finally did a thorough investigation and found the source. I fixed it by drilling two 3/16 holes and riveted it down...hope this helps you out.
The mount for the prop rod that is on the hatch is not a solid part of the fiberglass hatch, it is epoxied to it. One of mine is broken and someone has tried to fix it before. They drilled 5 holes around it and injected epoxy but it broke as well.
I tried to fabricate a fix for it out of 1/4" plate with a threaded center and a shorter ball stud that is riveted to the accessible underside of the hatch instead of the inside of the hatch. The force from the strut just ripped the rivets right through the fiberglass.
After that I just left of the portion of plastic trim that covers the rear latch on the hatch and it has minimal squeaks now. I don't hear it but on a very rare occasion. I guess the strut was rubbing the plastic trim and causing this super annoying squeak.
