Sponsored by: CARiD
right rear noise
Old Jun 5, 2010 | 10:02 PM
SSickLS1SS's Avatar
Default right rear noise
its a strange light metallic noise coming from the right rear and only happens when i go over a bump on that wheel.
all bolts are tight
everything is where it should be, tightened and all
02 SS with 23k miles
only mods back there would be bmr springs, panhard, relocation brackets and LCAs
driving me insane idk what to do
and the sound definatley sounds like its coming from outside the car
Old Jun 5, 2010 | 10:09 PM
eseibel67's Avatar
Few ideas: Control arm bushings, shock mounts, loose spare tire.
Old Jun 5, 2010 | 10:12 PM
SSickLS1SS's Avatar
tyy will look into those tomorrow
Old Jun 6, 2010 | 10:05 AM
SSickLS1SS's Avatar
any other suggestions?
Old Jun 7, 2010 | 06:11 PM
SSickLS1SS's Avatar
those all seem to be fine..now what
Old Sep 26, 2010 | 12:20 AM
blue95's Avatar
Any luck fixing this? Mine has started to make the same noise and I can't locate it. Replaced the rear shocks and it's still there.
1999 Camaro SS Stock everything
Old Sep 26, 2010 | 05:43 AM
transamtom's Avatar
Maybe the spring perch isolating rubber is worn causing metal to metal contact(spring/axle)
Old Sep 28, 2010 | 08:54 PM
crispytoast's Avatar
Mine was doing that at one point and it turns up the right rear spring was catching on the panhard mount bolt (I think that was a product of the geometry of my car being messed up in a rear end incident with a botched body repair) I just turned the spring so that the coil that was catching was oposite of the bolt and all is well. I found this by crawling under the back of the car as far as i could and having someone bounce the back of the car as I listened and located the issue.
Old Sep 28, 2010 | 10:48 PM
98pontiac's Avatar
was everything tightened while it was up in the air? or was the suspension loaded on the ground? Everything should be tightened with the suspension loaded. Otherwise, be patient, get under there and go over everything... take breaks, sometimes your mind can go crazy thinking the same thing over and over... if you have tried one thing, make it a point to try something different than the previous. Avoid checking the same thing over and over... unless your are REALLY out of options..
