Sponsored by: CARiD
Help... another A/C issue
Old Jun 7, 2010 | 11:55 PM
spicy's Avatar
Default Help... another A/C issue
My A/C blows cool air but not as cold as it should be and the heater works fine. My Haynes repair manual says to check the two lines that run to the evaporator and that the receiver/drier line (larger and on top of the smaller line) should be cold to the touch and the smaller line should be warm. Well when i went to check it today the smaller bottom line is cold and the top big one is warm, is this correct and my manual is wrong. Or is there someway the pumps or piping got reversed (i bought the car used)? Any help is greatly appreciated.
-Brian
Old Jun 8, 2010 | 09:00 AM
samson_420's Avatar
Look through the other million AC threads in here. . . I think every possible condition has been covered twice.
Old Jun 8, 2010 | 03:50 PM
fleetmgr's Avatar
Doubt they are reversed. Did you check them with the engine running and the A/C on? However, feeling these pipes won't tell you much. Take the car in to someone that has a clue about A/C.
Old Jun 8, 2010 | 05:03 PM
spicy's Avatar
yes the car was running when i checked, right now im trying to verify which line is supposed to be cold so i can go from there. I know i read a post awhile ago that stated which one but i have been unable to find it. Ill just keep searching for now.
Old Jun 8, 2010 | 07:50 PM
senicalj4579's Avatar
When you say it blows but not as cold as it should be what do you mean? It was colder a prior time? If so how long ago?
theres no way the pipes got reversed.
Old Jun 8, 2010 | 08:01 PM
spicy's Avatar
I bought the car used so i dont know how cold it used to get but i know for sure that it should be colder than it is. Its kind of like turning on a ceiling fan in your house, doesnt exactly blow cold air but feels cooler.
So is the smaller diameter pipe supposed to get cold or the larger one? The small one gets really cold to the touch and gets some condensation build up. If this is normal ill just check the freon pressure and go from there. I just want to make sure im not missing something before i start messing with it.
Old Jun 8, 2010 | 08:39 PM
fleetmgr's Avatar
the larger pipe should be cold(er), but if you're short of refrigerant it may not be. The small one is the liquid refrigerant line going from the condenser to the evaporator.
Sounds like you have a refrigerant leak, and need to find and repair that in addition to having in charged.
Old Jun 8, 2010 | 09:14 PM
spicy's Avatar
Appreciate the input. I was messing with it today and could feel some air being blown out from some where closer to the firewall but i burnt my hand on something and called it quits for the night.
Old Jun 8, 2010 | 09:38 PM
Yes this is right.
But first hes gotta find out if he really has a leak.
spicy,are you gonna do everything yourself or are you gonna pay someone?
Old Jun 8, 2010 | 09:54 PM
spicy's Avatar
Im going to try to do everything myself or at least trouble shoot it until i know for sure what is going on with the a/c. Once i figure that out i should be able to get a rough estimate from a repair shop. My plan is to go to auto zone tomorrow and recharge the system with dye so any leaks should be easier to spot.
Old Jun 8, 2010 | 10:16 PM
I just did my civic last week. Had to change the compressor,hook up my vac pump to pull a vacume,saw I had no leaks,and charged her up.
Do you have r134a gauges and Vac pump? If not maybe you can borrow from someone or rent them.
Old Jun 8, 2010 | 10:32 PM
spicy's Avatar
I know auto zone has gauges i can use, ill ask about the pump when i go there tomorrow.
Old Jun 10, 2010 | 06:10 PM
spicy's Avatar
Well, low side pressure is good at 40psi @ 70 degrees. I guess ill check high side pressure and do some more searching on what causes the problem I have. If anyone has advice or experience please chime in.
Old Jun 10, 2010 | 06:38 PM
do you know for sure that the compressor is running?
