fuel injector service
Old 06-15-2010, 08:38 PM
Moderator
thechef's Avatar
Default fuel injector service
ok i want to do a fuel injector service on my 99 NBM trans am, i got a injector service kit that hooks up to the fuel rail, pull the fuel pump fuse set the pressure with the guages and disconnect the fuel pressure regulator? where is that and how do i disable it?
__________________
Old 06-15-2010, 08:59 PM
cpo
cpo's Avatar
Where did you buy the kit, and what is the part number if you don't mind me asking?
Old 06-15-2010, 11:20 PM
eseibel67's Avatar
REgulator is in the tank, no need to disable. If you pull the fuel pump fuse, it will run on the cleaner.
Old 06-16-2010, 06:39 PM
cpo
cpo's Avatar
I've searched to no avail, what is the part number to said kit, and who sells it? Thanks in advance.......
Old 06-16-2010, 09:18 PM
Moderator
thechef's Avatar
its a Borg warner kit it does lots of different types of cars, it s for shops maybe you can find it somewhere online
Old 06-16-2010, 09:30 PM
cpo
cpo's Avatar
ic, thanks......
Old 06-17-2010, 08:49 PM
Moderator
thechef's Avatar
the kit says Pro Cleen on it and its made by borg warner
Quick Reply: fuel injector service
