Sponsored by: CARiD
Problem!
Old Jul 20, 2010 | 09:46 PM
JcsBlk98z28's Avatar
even if i plan to get work done on the heads and get a cam?
Old Jul 20, 2010 | 10:13 PM
fleetmgr's Avatar
Yes, get a stock one even if you mod it.
Old Jul 22, 2010 | 10:42 AM
NSSANE02's Avatar
^^^ That. You can get a GM 85mm if you want but the stock one will do just fine, even with heads and a cam.
Old Jul 22, 2010 | 08:22 PM
just found out its not the maf.
on the driverside valve cover there is like a hose that leads to it thats completely burned apart anyone know if thats causing the problem?
Old Jul 23, 2010 | 12:41 PM
NSSANE02's Avatar
On the back of the valve cover?
Old Jul 23, 2010 | 05:19 PM
yeah it looks like its on the valve cover and it looks like it comes all the way around to the intake manifold right below the tb.
Old Jul 24, 2010 | 08:07 PM
it was the pcv hose. but still not the problem ran the codes today and all o2 sensors went off my mechanic says its the fuel pump?
do you think that might be it?
Old Jul 24, 2010 | 08:22 PM
71novaguy's Avatar
A loose nut behind the wheel
Old Jul 25, 2010 | 02:17 PM
what?
Old Jul 25, 2010 | 05:35 PM
i bought the car pretty messed up and im just trying to fix it all and after i find this problem it should run pretty good.
