Sponsored by: CARiD
Help! Car starting probs!
Old Jul 26, 2010 | 03:12 PM
FNQUIKWS6's Avatar
Exclamation Help! Car starting probs!
Hey guys,
My car started fine this morning but after parking the car for about an hour and getting back to start it was a big hassle.
It will not turn over, just makes a 'click' sound. After trying for a few times, it BARELY turned over and I got it to start. Happened again as well.
Is is the starter? What should I be looking for?
Thanks for the help!
Old Jul 26, 2010 | 03:14 PM
ItsNotStock's Avatar
Dying battery would be my guess.
Old Jul 26, 2010 | 03:22 PM
jcobra99's Avatar
First of all does your battery have enough power the crank the starter?
Old Jul 26, 2010 | 03:23 PM
2001NBMZ28's Avatar
My guess too - check battery voltage, cables and/or have it load tested. Sometimes you get rapid clicks, sometimes clicks once and is completely dead.
FNQUIKWS6's Avatar
Nah, my voltage gauge was reading steady at 12-13volts..... Usually with a dying battery I didnt think that would be the case? The battery isnt that old either...
Old Jul 26, 2010 | 03:24 PM
FNQUIKWS6's Avatar
Oh and I had thought that too and had my buddy jump me off with some cables which did NOTHING for the car. It would still only click...
Old Jul 27, 2010 | 08:49 AM
Mereniuk's Avatar
I have the same problem right now... Just a Click. even put in a new battery. Still just a Click! you fix your problem yet?
Old Jul 27, 2010 | 08:53 AM
Mereniuk's Avatar
Just wanna know if it the Theft System or the starter before i start tearing **** apart!
Old Jul 28, 2010 | 01:09 PM
jcobra99's Avatar
Start by taking your starter to a auto parts store and get it tested. Also check all your fuses..
Old Jul 14, 2011 | 07:47 AM
ramairetransam's Avatar
What was the outcome. I'm having this problem today. Missed work bc
Of it. Got a new battery. Other was 6 yrs old and used in a summer only car. New battery in. One click. And I've charged the battery too The brand new one.
Old Jul 14, 2011 | 07:57 AM
xBrian's Avatar
Old thread but; if your battery is good (check voltage on the dash, or does your horn blow, lights come on, and wipers all work) and the car still won't whirl over, its the starter.
Old Jul 14, 2011 | 09:02 AM
yeah i know old thread , lights are good all the power is good on the new batt and Ive charged it some too . also just went to advance auto and they tested the starter , its fine.
wtf do i go from now . The car hasn't been messed with recently and i drove it home yesterday fine and no starting probs or anything . Parked it after work and then its in the garage no on jacks .
Old Jul 14, 2011 | 09:41 AM
killagt's Avatar
sound exactly my problem 2 week ago, its the starter.
edit oh nvm I just read your post above.
Old Jul 14, 2011 | 09:54 AM
i checked the clutch switch and all thats good , i hope the key all the way turned and press the clutch and i get a click so i know the clutch safety stuff works .
Where the click im hearing , starter , is it possible it tested fine and now wont work , if it was 50 bucks i might just buy another but at 180 and they sid mine is fine i have a real hard time buying one .
Old Jul 14, 2011 | 10:34 AM
perezpowerbuilders's Avatar
If you had the starter checked and it tested fine....then I would check the ground wire from the selonoid and check all ground wires....I had intermittent starting problems and I couldnt figure out why....found out the ground wire at the starter selonoid was rusty...cleaned it up and fixed the problem....hope this helps.
Old Jul 14, 2011 | 04:47 PM
Solved after lunch today , it was a bad connection between the battery and the side post wire holder , changed it and then tested the starter hanging with it grounded to the frame with a jumper and it worked , so crossed fingers and worked, bougbht a new bettery but the other was old , o and the new battery much higher voltage used to be around 13.2 now 14.2
