Sponsored by: CARiD
A/C compressor has gone out
Old Jul 26, 2010 | 10:43 PM
CubanGT's Avatar
Default A/C compressor has gone out
Just wondering what my options are for a replacement.
I got Orielly's price for reman = $242 plus $10core and if i want the warranty, need to get the hoses $80
So that way is $322
Called the stealership and got price and part # to look up on gmdirect..
Gmdirect = $379
Jegs i found some, but are not specific on what it fits, just says what type of connections it will accept. But a nice chrome one is $279(#555-51806)
So right now Jegs is looking like the better deal, we are working on replacing parts as needs with chrome and so on to dress up the motor a little bit. And since the compressor went out, now would be the time to get the chrome one if it will work.. Can anyone tell me if the Jegs part listed above will work on a 99TA?
Old Jul 26, 2010 | 10:57 PM
HotSilverBird's Avatar
http://cgi.ebay.com/ebaymotors/AC-CO...Q5fAccessories
Old Jul 27, 2010 | 12:02 AM
fleetmgr's Avatar
Regardless of which one you get, if you've had a compressor die and replace it without flushing the system, you be replacing it again very shortly.
Old Aug 5, 2010 | 10:25 PM
CubanGT's Avatar
So i borrowed a leak detector and put some new freon in, a/c got cold, worked my way up and down each hose and connection. As well as areas close to the connections and hose and never found any leak.. what else could i check for? and when "fleetmgr" says flushing the system, what is involved in that? i dont want to mess anything up if i do replace something.. if its not hold the freon, is there really anythign to flush?
Old Aug 5, 2010 | 11:35 PM
fleetmgr's Avatar
What I mean is that if you have a compressor failure (and based on your last post, you may not be there), you sling all that metal from the dying compressor out into the system. All that crap may or may not get collected in the orifice tube. If any of it gets past the orifice tube, it will migrate to the new compressor. When it does, your new compressor bites it.
If it just collects in the orifice tube, you end up with a system that won't cool because the orifice is plugged. It also can collect in the condenser and decrease efficiency there. It MUST be flushed out. There is a special cleaner used to do this, and essentially you blow the cleaner through the system with compressed air.
But, if your compressor is still working then you are right, there's nothing to flush. Sounds more like you just have a leak. Check the 2 most common failure points...the compressor crankshaft seal which is right behind the clutch, and the compressor casing seal, where the compressor halves come together. If the leak is at either of those 2 spots, you'll still need a new compressor because the parts required to fix a leak at either point aren't available. But you won't need to flush the system. You'll also need to put more oil in the system when recharging. If it leaks refrigerant, it leaks oil too.
Old Aug 6, 2010 | 09:26 PM
CubanGT's Avatar
Then im at a loss.. i have still a borrowed leak detector.. the sniffer.. i put some freon in and ac began to blow cold.. so with the detector, i placed it at ever hose end and down and around each hose.. got under the car and placed it over and under the compressor and behind the clutch.. and it never went off.. now to make sure, i placed it next to the connection where i was putting in the new freon and once i removed the can, it went off.. so i know it works and senses the freon.. but could never find any leaks.. so what should i check or do next?
Old Aug 6, 2010 | 10:11 PM
fleetmgr's Avatar
Next step is to put some dye in the system and see where it comes out. Incidentally, did you check the Schraeder valves for both the high and low pressure sides? They can leak, too.
Old Aug 8, 2010 | 09:49 PM
CubanGT's Avatar
Figured as much ive spent about $50 in freon over the last month trying to find it and could have just spent that on the dye kit and probably already found it.. but ill try that next.. i think i know someone that may have the kit already and could borrow it..
thanks.
Old Aug 11, 2010 | 12:29 PM
Count of Monte Crlo's Avatar
I just went through the exact same circumstance as you describe. Everything the same. Just as fleetmgr suggested mine was leaking at the compressor seals. $762 later, all good. Sorry to break the bad news to you.
Old Aug 11, 2010 | 01:08 PM
CubanGT's Avatar
Why so much? Did you do the install yourself? if it comes down to the compressor, im going to get the gmdirect one for it. Did you replace the hoses also? i can get the hoses for $80, just wondering if i should go ahead and do that when i replace the compressor.
Old Aug 11, 2010 | 03:01 PM
fleetmgr's Avatar
There no reason to replace the hoses if they aren't damaged.
Old Aug 16, 2010 | 03:34 PM
BIG_MIKE2005's Avatar
This is where I'm at right now. I had to replace my low pressure side tube cause it was broken off at the condensor. So I replaced that, threw in a new orifice tube & got it charged. Everything worked & was blowing 50* then a couple days later my car died & overheated. My alternator had been on the fritz for a while so I figured it crapped out again now that the AC was being used. Got under the car to remove it & noticed my AC compressor leaking where the halves meet. Just some tiny air bubbles & green liquid. Called the shop that charged it & they told me their dye is green they use & my compressor is leaking. So I'm gonna buy my buddies compressor he is removing to make a race car & swap it into mine since I know mine hasnt completely failed yet, just started leaking. Then off to get it charged again. Guess the first charge was a waste of money.
Old Aug 18, 2010 | 12:56 AM
LT1/TA's Avatar
If it's like other GM compressors the shaft seal on the front is leaking and possibly the seals on the body of the compressor.I have never resealed a V7 compressor like on yours,but I have put new seals in many V5,Hd6,and Ht6 GM compressors.
I resealed the Hd6 compressor on my Bird a month ago and it's doing great.The seals cost about $30 and it only takes a about an hour to reseal one once of the car.It sure as hell beats paying $200 for just the compressor for my car.
Old Aug 18, 2010 | 08:45 AM
CubanGT's Avatar
I can def get under there tonight to check what i have, is there something stamped into the casing of the compressor that will tell me what i have without removing it?
Old Aug 18, 2010 | 10:40 AM
LT1/TA's Avatar
I saw in your first post 99 TA so I checked it and it called a V7 compressor,If you are considering resealing it you with need a clutch plate remover/installer $17.05 shipped from ebay,a three jawed puller around $10,and a pair of snap ring pliers.You can probably rent the clutch plate tool and puller from an autoparts store.
I would put some dye in the system before you pull anything so you can verify the leaks.
Old Aug 18, 2010 | 10:03 PM
CubanGT's Avatar
Well i bought the leak kit, had i bought this a long time ago i would have saved alot of time and money.. During one of the times we were checking the system a while back.. we had used some of that freon with the leak detector already in it. Well needless to say, as soon as i turned on the uv light and started to look, the entire top portion of the compressor was glowing green from that dye.. I didnt have to use the kit, so i may just take it back and only buy the uv light to have in the future.. i have spent to much on trying to find it and if i would have done the leak test first, i would have found it and had ac by now.. So at this point, we are looking to order the compressor from gmpartsdirect.com and be done with it.. (dealer part#1137028) and (gmpartsdirect part# 89018956) im waiting to hear back from customer service to make sure thats in fact the part needed for the car.. is there any reason, besides cost, not to get the compressor? Looking at the cost of the parts needed, its pretty expensive, i rather not rent the tools as i tend to work on cars alot, i would eventually need it again. Calculating it came out to about $100 new for the cheapest ones and $30 for used ones from ebay. Now looking online at the autoparts store, all i can find is this one, is this what i would need?
Santech/Compressor shaft lip seal kit for GM/Harrison V7
http://www.autozone.com/autozone/acc...er=946289_0_0_
if so, then i may just go the used parts way and do the reseal for about $50 with tools..
Old Aug 19, 2010 | 12:52 AM
LT1/TA's Avatar
PM sent
Old Aug 21, 2010 | 02:18 PM
CubanGT's Avatar
Only issue now is the top bolt holding in the compressor, i have everything else off from under the car, just need to remove the top bolt and cant get the right angle to remove. Any suggestions on how to remove it?
Old Aug 30, 2011 | 09:44 AM
tiny2399's Avatar
Default V7 info
the V7 compressor shaft seal is held in by a snap ring and once you get the ringout a simple pair of long nose pliers will get the seal out(a little pressure in the system will push it out also..lol) the only thing that needs to be removed is the clutch itself, the actual seal is internal behind the clutch and taking the pulley and the coil off the front of the compressor will not help you with access at all so leave it in place. the pulley is pressed on the outside of the casting where the seal is. I did mine on an s10 and left the compressor on the vehicle, but with yours being on the bottom it will probably be easier to work with and see also if its is off the car. rent the clutch puller from Oreilly's it makes the job simple and also make sure you check the clearance measurement from the clutch to the coil during install ( there is a specific gap) Don't forget to lube the shaft and the seal with PAG150 oil prior to install also. Good luck!!!
Old Aug 30, 2011 | 10:35 AM
jam01's Avatar
if the ac was blowing cold after putting freon in, it wouldnt be the clutch. are you sure the compressor is leaking, you checked all the hoses and fittings for leaks? not saying it isnt the compressor, but the length of time you say between tests the stuff could have gotten on there from dripping.
