Sponsored by: CARiD
Engine build help!
Old Aug 10, 2010 | 09:24 PM
bboylastik's Avatar
Default Engine build help!
First off i have never built an engine before. Ok so im doing an ls1 swap on my 240. Since i had the engine on a stand i figured i would replace the cam, springs, and rod bolts. I tore it to a short block. I sprayed everything with tons of brake cleaner. I put the new springs cam and rod bolts on. Since i cleaned everything with brake cleaner, before i just throw it together, do i need to grease or oil anything or check anything? Please any tips or suggestions would be helpful. Thanks guys
Old Aug 10, 2010 | 10:25 PM
Anthony Williams's Avatar
Too much detail for a thread, Get yourself a copy of "How to build hi performance LS1/LS6 V8s"
