How to remove the top bolt from AC compressor
Removed the bottom 2 bolts, the line from the back of the compressor and now i cant seem to get to the top bolt.. is there a trick to removing this bolt? is there other items i need to remove in order to get this out?
I went and bought a 18" breaker bar and im able to get the socket on the bolt, but still no room to move the wrench..
Thanks
If you're having trouble breaking the bolt loose I'd spray some PB Blaster penetrating oil on it. lay a pry bar on the ratchet and give it a few taps with a hammer.
There's 3-4 bolts that attach the bracket to the motor block. you shouldn't need to remove them. and the 2 on the bottom you can only remove after the compressor is off.
Good luck
