Sponsored by: CARiD
HELP! AC condensation leaking from under dash!
Old Aug 28, 2010 | 01:57 PM
ninetres's Avatar
Default HELP! AC condensation leaking from under dash!
As title says, after my AC has been on for more than 5 mintues (2001 SS)..........if I take a corner with any kind of spirit I get an ice cold splash of pure water on my feet. SO etimes it seems it is more than a few ounces that come cascading down. As good as this feels in the Fresno, CA heat (lol), I would love to fix it. I imagine some kind of EVAP hose has came loose. Right? Wrong?
My question is: Has anyone done this? Any tips? I will do anything possible to not remove the dash as it is a PITA.
Please help. Thanks!
Old Aug 28, 2010 | 10:01 PM
fleetmgr's Avatar
There is a drain line off the evap box and its become plugged with snot (dust+water). Run a coat hanger up the line, and your problem will go away.
Old Aug 28, 2010 | 11:09 PM
ninetres's Avatar
Is it possible to get to without removing the dash?
Old Aug 29, 2010 | 07:09 AM
fleetmgr's Avatar
You get to it from under the car.
Old Aug 29, 2010 | 10:21 AM
ninetres's Avatar
No ****. Thanks for your help! About where does it dump?
Old Aug 29, 2010 | 11:46 AM
2001NBMZ28's Avatar
http://shbox.com/1/a_c_drain.jpg Ours is similar.
Old Aug 29, 2010 | 10:07 PM
ninetres's Avatar
Sooooooo you guys are AWESOME. I found that hole that 2001NBMZ28 posted. I crammed a hanger up there a bit and a bunch of water came pouring out!!!!! I hope this solves the problem! Thanks again! Cross your fingers!
Old Aug 31, 2010 | 10:23 PM
ninetres's Avatar
Hmmmm. It still does funny things when I start the car......without the AC on. I get a bunch of huminity fogging up the windsheild in the center......near the dash vent. Weird. Espicially since I live in the 90*+ Fresno heat.
Old Sep 1, 2010 | 03:07 PM
2001NBMZ28's Avatar
More noticeable at night? Is the switch on vent? Inside windshield dirty?
Old Sep 2, 2010 | 02:00 AM
ninetres's Avatar
Maybe. No. Kinda.
It does it in both day and night, more at night I guess. Usually the following stratup after I ran the AC pretty hard. The switch is always at off when I start my car. The window isn't 100%clean, but not dirty by anymeans.
