Sponsored by: CARiD
Failed smog check, need some input
Old Sep 28, 2010 | 01:09 PM
  #41
LS14EVR's Avatar
Originally Posted by Searching4Sierra
thanks for your input, since i already paid for the o2s im just gonna wait till they get here and install them, but i will be trying the iso-heet trick for sure. its sold at standard auto parts stores, correct?
Cool. Understood.
I would say yes, but since you live in a warm climate, they may not sell it. I live in MI, so during the winter, you can find it anywhere. Good luck
Old Sep 28, 2010 | 08:32 PM
  #42
Searching4Sierra's Avatar
Ok i got some today, but the only thing i am interested in lowering is the NOx
will iso-heet lower this number? Or could it possibly lean me out and raise this number??
Old Sep 28, 2010 | 09:13 PM
  #43
wssix99's Avatar
Save the manuals!
Do you have to pay for the extra tests? If not, you should probably just go take a spirited drive to heat the cats and see if that plus your new O2s gets you by the mark.
Old Sep 28, 2010 | 09:31 PM
  #44
yes i have to pay....so that was my only concern. Otherwise i would just try it with the isoheet
Old Sep 28, 2010 | 09:50 PM
  #45
BlueMagicSS's Avatar
You cannot accurately diagnose a smog failure without taking the other numbers into account, did the HC's drop below Average or are they higher than average, are the CO's low or high? It seems like you are running in circles because you are listening to backyard mechanics. I have smogged many cars, some that have sat and cooled off before a test, even OVERNIGHT and I have came in at 8:00 and they passed, it's not because the car isn't hot enough. High NOx is caused by anything from high combustion temps, EGR failure, CAT failure, a lean condition, etc. An EGR solenoid can be mechanically functional but electrically bad. It needs to be commanded open with a Scan tool before you can determine that it is bad, or good. My GUESS is a bad EGR, but it could be a bad cat. It cannot be determined without the proper tests and without seeing the ACTUAL VIR (Vehicle Inspection Report).
Matthew
CA Licensed Smog Technician
Old Oct 1, 2010 | 11:53 PM
  #46
stubbs4's Avatar
Default help
not to thread jack or anything but what would make all my O2s not work i am all stock and have sims after the cat but does throw codes as well any input would be helpful
