Power steering leak
I was wondering if anyone else has had this problem and if so is it just a line that needs to be replaced?
Also what kind of power steering fluid do these cars take? Is it just regular ATF or is there a special fluid?
Also I've seen power steering fluid with stop leak. Is this wise to use and if so would there be any negative effects of using it / using it for an extended period of time?
I think I paid about $30 at Advance Auto fo the line.............took me about 15 minutes to replace it....very easy.
-I disconnected to the bottom line from the rack and let the fluid leak out into a pan. The reservoir drained completely. Then I disconnected the top line from the reservoir.
-I then loosened my serpentine belt for some wiggle room when I got the line disconnected.
-Then I pulled the line up through the top and around the alternator. (you'll just wiggle it out any way it comes, it comes free pretty easily.)
-Snake the new line into place..........and tighten both ends down.
-Then re-fill the reservoir....start the engine.....run back over right away and fill it up to the proper level. Go back and turn the wheels side to side, then check the level again.
-DONE.
Regular ole' power steering fluid is all our cars use.
Either way though.....If you do or don't have it....I suggest putting on an aftermarket cooler. $40 in parts and literally 15 minutes of your time to install it. Phillips screwdriver, razor knife, 3 feet of 3/8" heater hose, 2 band clamps.
Check my pics. It keeps my power steering fluid just warm to the touch.
