is this a window motor problem?
However the window works fine if it is in between the completely up and completely down area. This problem has been getting progressively worse and the window is on track and the regulator works fine. I just want to make sure that it is a motor problem or wiring before I buy a new window motor. Help appreciated
https://ls1tech.com/forums/appearanc...-write-up.html
