window motor and regulator
hey, im new and need help with replacing my passenger side window motor and regulator. i already have the door panel off and i have the parts i got the rivets out but the round part will not come off. therfore, i can not get the motor or regulator out! if anyone could help me i would highly appreciate it.
Save the manuals!
What round part? Once you have the four rivets drilled out on the regulator, you need to put a wedge in the window to the glass doesn't crash down on you, then you need to unplug the motor by removing the door speaker and getting your hand up in there, and then it should slide out the back of the door once you un-hook the regulator from the hole punched in the door.
Can you post a pic?
Can you post a pic?
