Upgrading to Truck Alternator
do you even need one?
going to a bigger, true high-output, alternator also uses more hp.
just get a reman'd with a warranty from a local parts store.
the issue is not with the total output of the alternator, such as 100amp vs 155amp.
the issue is usually at idle or low rpm and the alternator not spinning fast enough to provide the needed power, and can be solved with an aftermarket alternator pulley that is slightly smaller which will spin the alt. faster, and can be gotten for < $50 last I checked.
