car idles low then dies? help
i just got done installing my pace lt's and texas speed rumbler system , the lts only have one o2 bung . so i tried the rear o2's connected to the header bung , and car is still dying . so i used the wire that came with the texas system , to extend the front o2's back to the header bung , and still it is dying
although it could be me messing up the wire's splicing makin sure the wires are right bla bla
but i just want to make sure im not missing anything big
i did however take my egr out , but i read that it doesnt cause anything like this? also fabbed a plate to go on top of my TB
help?
help?
my car'll idle all weird and start to die on me a for a little while after i have the battery disconnected. no idea why. i just let it idle, take it for a short drive, shut it off, crank it up, and it's fine. with your O2's, the front's should be in the header bungs and the rears should be thrown in the trash. you don't need them.
help?
help?
Didn't you get o2 extensions with the headers? Use them, with FRONT o2 sensers, not the rear ones. You shouldn't have to splice anything. Removing the egr will throw a code, but should not make it idle weird if everything is blocked off.
