Hey everyone my car has definately seen better days. it has been leaking oil (well and power steering and coolant) lately. I figured it was the rear main seal and so i and a friend replaced the seal last week. got it all finished and started her up. but it still seemed to leak a little, less than it did tho! Well today i decide to get under the car and make sure all the oil pan bolts are tight. I decide to check the two bolts that pull the plate down on the back of the engine, and one is quite loose and the other is tight! yay i think and begin tightening it but it would not get tight!(oh shoot) then snap the bolt broke and fell out
. I started up the car and it doesnt seem to be leaking ( at least anymore than it did) do you think i will be okay without this bolt? also could a shop drill the broke peice out without removing anything? thanks here is a pic
