Clutch Pedal Squeak
With 36K miles, I'd guess that your return spring will go out on you in another 3,999 miles. You may just wait until that happens and you need to put a new spring in. Its a lot easier then.
It has a rubber button that goes in and out, and if it dries out, it will squeak like crazy. You can remove the switch (push the assembly up and it will pop out), take it apart, and grease the rubber contact area, or you can also just buy a new switch for like 10 bucks.
Happy thanksgiving!
