Sponsored by: CARiD
belt squeek
Old Nov 30, 2010 | 01:08 PM
cac12_05's Avatar
Question belt squeek
I have a 2010 SS camaro 6.2l with 10k miles and just recently one of the belts started to squeek. I can spray it with belt spray and right away it lets up at idle but once I get going it squeeks till it's warmed up. Could I need a new belt? The one on there doesn't look damaged at all. And it's a brand new car I bought it will 200 miles on it.
Old Nov 30, 2010 | 03:47 PM
cac12_05's Avatar
bump****
Old Nov 30, 2010 | 03:54 PM
camarolover209's Avatar
why don't you take it back and let them check it, it will be free because you should have a warranty.
Old Nov 30, 2010 | 04:06 PM
ULTIMATEORANGESS's Avatar
probably your tensioner. GM refuses to make one that doesnt make noise it seems.
dont spray any more lube on there if youre going to warranty it. dealers can be a PITA lately.
Old Nov 30, 2010 | 06:09 PM
cac12_05's Avatar
ok thanks for the info that's what i was going to do just wondered if you guys had any tips
I'm taking it in tomorrow
Ultimate what's that tensioner everyone is getting starts with a K doesn't it?
Old Nov 30, 2010 | 06:31 PM
68Problemchild's Avatar
I have a 6.2 L92. Tensioner squealed like a pig. Lots of shimming with 1/64 shims on the Kwik AC bracket.
I swear if it was a hair off, it squealed.
Finally after getting squeal to a minimum with shimming, put on a 1/2" shorter belt and its gone, for now....
Old Dec 3, 2010 | 08:12 AM
cac12_05's Avatar
update I took it to the chevy house and they're over nighting a new "upgraded" belt so I guess GM is tryin to fix the squeeking issue by making a better belt but we shall see. I get it put on today and will let you guys know if the squeeks gone.
Old Dec 4, 2010 | 09:48 AM
cac12_05's Avatar
Well the belt worked no squeaking what so ever they ended up having to replace every belt bc of the belt spray i sprayed on it apparently deteriorates the belts. Luckly the guy had chevy cover everything!
