Sponsored by: CARiD
Emissions help needed
Old Dec 1, 2010 | 06:00 AM
cambirdracing's Avatar
Default Emissions help needed
I have a lowly 94 Bird with a 3.4. Won't pass emissions testing to get an inspection.
Test 1: High Nox at the 25mph test. I knew the EGR valve was bad, replaced it.
Test 2: I have higher Nox at 25 and High CO and Nox at 15mph.
Could a bad Cat cause this. About a 1 1/2 years ago, had bad gas and the cat was glowing cherry red. It is only about 3 years old.
Old Dec 1, 2010 | 06:56 AM
00'WS6Rocket's Avatar
I had the same thing with my 92 i never figured it out before it was stolen. Youvpuld try this https://ls1tech.com/forums/showthrea...ghlight=Seafoa. When it cleans the top end it clears out carbon buildup. Which maybe causing your high nox
Old Dec 1, 2010 | 06:58 AM
I also had changed the egr and cat. But niether fixed the problem. At least in my case
