help with brake light =(
If its the cluster light, I'll bet one of two things:
75% - A) Something is messed up at the switch at your brake lever. Someone may have shorted the connector, etc. to compensate for a bad switch. (When the switch goes bad, the BRAKE light is on all the time.)
25% - B) Someone covered the LED bulb on the instrument cluster or the LED is bad or has come de-soldered from the instrument cluster. Before you check this, you'll want to check the connector at your brake handle switch, make sure its getting power, and that your switch is working properly. (Closed with brake off and open with brake on.)
