Part-throttle hesitation and stumble...
So the GF's car does fine at WOT but at about 30-50% throttle has a nasty hesitation. Its in multiple gears.
The car has been seafoamed but thats about it. Any ideas?
Oh and its throwing no codes at all
i had a very similar problem...turned out one of my spark plug wires seperated at the boot to the spark plug, i just berely touched it and it came apart. Might want to check the wires
2 days ago i noticed my car started to stumble between 40 and 50 mph, let me know any new updates, i plan to check my plugs and wires and change fuel filter. Now that some here post about 02's maybe i change those too, 149k miles and still have the original 02' sensors.
www.rockauto.com Densos #2344087 I believe.
amazon.com also........
Well cruising you are using the 02s and WOT you are not so it could be 02s but it could be other things like dirty injectors, tune up,vacuum leak, loose intake bolts etc. I had a hesitation at about 25% throttle and it turned out to be rusted fuel lines. All the injectors had rust in them from the fuel lines. It ran great WOT. If you pull the Accumulator-pulsator on the fuel rail you can take a quick look inside the fuel rail and see its condition. Mine was full of rust.
I'm having the same problem with part throttle acceleration in 2nd, 3rd, 4th gears. I bought some 13444 Bosch O2 sensors last night and will be installing them Monday or Tuesday this week. I will post up and let you guys know if that fixes the problem.
I installed the new Bosch 13444 O2 sensors today...
results were 100% successful! No more hesitation/stumble between 2200-2500rpm at part throttle and my mpg's went up from 12mpg lol..
Thats right.......our PCM's are still just like the 1970's idiot lights.
Mine doesn't throw a code for bad MAF, bad TPS, bad 02's, or TCS issues. I got an SES light and a code when an 02 sensor went bad and finally would hardly let the engine run...then I got a light. Good thing it came on 1 mile from my friends place who threw the new ones in for me.
I was wrong guys. The hesitation is back and a little worse. Anything part throttle under 2500rpm it hesitates bad. I already did the rear O2s, fuel filter is good. It's also pinging above 5k..
id maybe have a look at fuel pressure and see what its doing, pump on the way out would seem like a bad fuel filter and the pinging at high rpm would seem like a lean condition, fuel pressure at idle should be around 48 i believe, you can pull the fuel pressure regulator vacuum hose off and see if the pressure jumps when you do. it should jump to around 56 pounds or so if the pump is good. just throwing out another suggestion.
