Noise after struts..
Dunno try to be discriptive.. Anywyas sounds like something is bottoming out..
any ideas.. my buddy at a shop said that it could be the rubber bussings in the mount.. car is 8 years old.. could this be??
BIG ROCK
Bad news is you have to remove the whole damn assembly to get to the nut.
Good news is that it fixed (my) problem.
I guess this is what happens when you trust your buddy to tighten nuts..
Strut Mount Gabriel Price: $ 17.71 Qty: 1.00 Part #: GAB142409
and two isolators Gabriel Price: $ 7.85 Qty: 2.00 Part #: GAB142412.
$51 solution from autopartswarehouse.
went down the road and heard the same noise the passenger side was making earlier took it back apart made sure the nut was tight on that side and put it back together..
Looks like ill be buying two new mounts and the absorbers and just say f it all and make sure its right.. Toms I was looking at those mounts and part numbers the driver side looks different or mabey im not that observant and they are different but the looked the same when i was taking them off.. oh well that autoparts store you posted its cheaper then the local autoparts store same mout is 60 at auto zone and 17..
oh yea does it have the bottom part that you spring sits into their picutre does it no justice..
