Sponsored by: CARiD
Engine table: how to clean block?
Old Jan 17, 2011 | 11:25 PM
pHEnomIC's Avatar
Default Engine table: how to clean block?
I want to make an engine table out of my old ls1.
I have the shortblock sitting around. what is the best way to clean it up by hand? I don't want to have to take it to a fancy shop.
Any ideas where to get glass and what size it should be? I would like to have it ordered so i can just throw it together one day.
Also, it is a blown engine (rod bearing) that would need machine work eventually. But, theoretically would taking it apart and using it as an engine table for a while hurt it from being used again as a rebuild block?
Old Jan 18, 2011 | 08:58 AM
O2Form's Avatar
Don't spill coffee on it and you should be fine.................
Old Jan 18, 2011 | 01:54 PM
NVR_SPDS's Avatar
The best way would be to hot tank it IMHO. I know you said you wouldn't want to take it to a shop, but if your going to rebuild it later, it should be done either way. Using it as a table shouldn't hurt it, as long as you don't scrape up the pan rail.
Old Jan 18, 2011 | 10:21 PM
joshp14's Avatar
Power washer if you arent taking it to a machine shop to get a hot bath..or some soapy water and stiff brissled nylon brush.
Old Jan 19, 2011 | 03:13 PM
LS6427's Avatar
Spend some time on it....and polish that sucker............
Old Jan 20, 2011 | 08:17 PM
NVR_SPDS's Avatar
That would be awesome!!!!!!
