Sponsored by: CARiD
HVAC Temp control cable splice
Old Jan 19, 2011 | 11:40 PM
man2004's Avatar
Default HVAC Temp control cable splice
In case I need to replace the HVAC unit on my 98 TA, I am just wondering if anyone has ever done the install. Splicing the temp control cable looks tricky since it is a moving cable in a sheath rather than a simple electrical connection. How do you splice the cable from the donor part to the car's existing cable? I believe the other connections are plug and play. Any information on the install would be greatly appreciated.
Old Jan 20, 2011 | 09:01 AM
wssix99's Avatar
Save the manuals!
You don't splice it. It's like a bike cable - you disconnect it and just hook it up to the new panel.
Old Jan 20, 2011 | 02:10 PM
man2004's Avatar
Oh. That does sound easy. I'll have to look at the back of the temp control section to see if I can figure out how to take it apart so that I can diconnect the existing cable. I hope that will do the trick. If the cable is tight after the replacement HVAC controls is installed, there might be a problem with the heater core door opening or the cable itself. I will give it a shot once I can get access to the car (it's stored at a friend's house). I will follow-up. Thanks for the info and assistance.
Old Jan 20, 2011 | 05:33 PM
wssix99's Avatar
Save the manuals!
Its really strange - you should be able to find a thread on this site with pictures. There is a white plastic cover over the attachment that needs to be removed. If needed, the cable is adjusted under the passenger side door under the dash - but you should not need to do that. Adjustment should only be needed as the spring in the cable wears out. (That spring is under the cable cover at the vent door.)
Old Jan 20, 2011 | 09:43 PM
Swiat34's Avatar
Yeah and it's WAY more complicated than cables in a sleeve! The cross section of the sleeve looks like an 8. Each cable has it's own tube. Just some interesting info. Like they said above, you can replace the whole cable.
Old Jan 21, 2011 | 01:51 AM
man2004's Avatar
Thanks for all of the info. I'm going to get a quick look at it this weekend.
