Sponsored by: CARiD
AC Belt Removal
Old Jan 18, 2011 | 03:01 PM
PassoutWilly's Avatar
Default AC Belt Removal
This may be a stupid question but can I remove my AC belt and still drive the car with no issues? Reason being is that it's squealing pretty loud and instead of buying a new one, I figure I'd just remove it since I don't hardly use my AC.
Old Jan 18, 2011 | 03:21 PM
2001NBMZ28's Avatar
Why not just replace the belt? Not expensive and easy to replace. Maybe it's not the belt but the AC tensioner squealing? Pretty sure the compressor runs in defrost mode to help clear the windshield.
Old Jan 18, 2011 | 04:49 PM
LS6427's Avatar
Yes, you can drive without it. Its easy to remove...but if you just want the damn thing off, get under there with a razor knife and cut it off in 5 seconds.
If you want to take it off......you first need to loosen the serpentine belt. Then get a ratchet on the tensioner pulley, pull down on it to loosen that tensioner and the belt slides right off. Takes 1 minute to remove it.
Old Jan 18, 2011 | 08:04 PM
Grimes's Avatar
Ditto. That's what my squeal was. If you look at the tensioner, and it is bouncing all over the place, it needs replacing.
Old Jan 21, 2011 | 09:21 AM
wssix99's Avatar
Save the manuals!
Do you use the defroster? The A/C is also part of that system.
Old Jan 21, 2011 | 09:40 AM
TARZAN's Avatar
Car will drive fine without it.
-Will
