Sponsored by: CARiD
Key Fob help please!
Old Feb 26, 2011 | 11:39 PM
GeneralsArmy's Avatar
yeah i had pretty much came to that conclusion, but at first i was just kinda thinking GM fob reprogram it'll work.
Old Mar 8, 2011 | 01:27 PM
LooseMoose's Avatar
I'm still having trouble with getting my car into program mode. I have done everything that JaYZeig said about 100 times. Double, and triple checked this. Also tried several other methods and the locks aren't cycling. Nothing Any ideas what I might be doing wrong?
Old Mar 8, 2011 | 08:04 PM
LooseMoose's Avatar
Finally figured it out. When I pull the radio fuse my radio still works??? So I pulled the power accy fuse and it worked first try. Weird
Old Mar 9, 2011 | 06:03 AM
impalandy's Avatar
Hi. just read your instruction on the programming and as i need to carry out th esame thing on My '97 Transam, wondered if you know if in removing the radio fuse, you lose the code for the radio. Checking as I don't have the code for mine.
Andy
Old Jun 7, 2013 | 07:46 PM
BigBlockNBK's Avatar
"Finally figured it out. When I pull the radio fuse my radio still works??? So I pulled the power accy fuse and it worked first try. Weird"
I had to do the same thing too
