Mice in the vents
Little bastard was still alive, they put it up in a tree. But MICE....damn, thats not gonna be easy. You could use a fogger and see what that does, but they if they don't come running out they will die. Then you better tear it apart fast to get them out or its gonna start to stink bad.
hi, I CONCUR WITH 427........OPEN DOORS AND DROP UNIT DOWN........I WOULD LAY A QUILT DOWN AND BLOCK ESCAPE ROUTE TO ENCOURAGE OUTSIDE EXIT........THEY SELL
AN ITEM( GREEN PEANUT) THEY EAT/ IT MAKES THEM SEEK WATER...... I WOULD REMOVE THE DASH PANEL. WEAR GLOVES/LONG SLEEVE SHIRT FOR THIS PROJECT. MAKE SURE YOU VACUUM ALL OF THE DEBRIS AND CHECK FOR WIRING
PROBLEMS/TEETH MARKS. GOOD LUCK............HAVE A BLESSED DAY...........JIM
I would expect the cleanup will be straight forward. (Wear a dust mask so you don't get the plague.) Rodents defecate in the same place, so only one area of the duct system should be soiled. (We had a similar issue in a building I used to work in.)
Mice can get in very small openings. You may look to see if you have a floor drain or the spare tire drain plug missing. Even if you get rid of one mouse, more will keep coming to get out of the cold weather.
Look at #21
http://webcache.googleusercontent.co...www.google.com
Did find out from the owner that they fed their dogs in the garage...well the mice had a steady food source and a nice car to live in.
