Fog lamps!
Fog lamps!
Hey guys my fog lamps are not working when I turn the lights on, the light on the button on the dash does not light up either (yes it is switched on).
However when I use the remote to lock my car they both light up to indicate the car has been locked.
Any thoughts? Seems wierd.
Thanks!
Thanks!
hi, check fuses first.......secondly, use volt meter and check for voltage at switch and fog lamp. you can check continuity to find breaks in wire.........fairly easy check.....good luck
and have a blessed day.............jim
