Car wont crank
In the worst cases where its happened I turn the key completely about five to six times and the starter will not crank. I've had the battery and alternator checked and they are both good. A few times the problem went away and the car cranked and started on the first try, although it USUALLY does not start easy like that now. So what the heck would cause this? bad ground? loose starter bolt making a ground? Any suggestions would be greatly appreciated!
