Sponsored by: CARiD
sarting problems need help!
Old Feb 22, 2011 | 12:31 PM
Camokid09's Avatar
Default sarting problems need help!
im just about done with my build on my 99 ws6 ls1 and i cannot get the car to start, i have not completly finished im still doing some gauge wiring and stuff but i cannot start the car(were not trying to start it up just"bump" it)
any ideas? here is what i modded
torquer v.2 cam kit... valve springs and push rods
ls6 intake
rebuilt tranny
yank 2800 stall
egr delete
sts turbo methanol injection and intercooled
any reason why it wont even bump?
the starter tested at autozone and passed twice
Old Feb 22, 2011 | 12:55 PM
mozmale's Avatar
check the ground to your engine
Old Feb 23, 2011 | 11:47 AM
Camokid09's Avatar
alright i will does anyone else have any other ideas? could it be the security sytem in the car or some thing(heard rumors bout tht)
Old Feb 23, 2011 | 12:12 PM
safemode's Avatar
if you still have VATS then you need to describe what happens when you turn the key. Does the starter not click? If not, do you hear a click at all as if from under the hood? If so, change out the starter relay and try again. If not do you have the Security light steady on always with the key turned to "on" ? If you do then you should bypass VATS with a resistor matching your key's at the connector under the dash and see if you start then. If the Security light goes out then you have some other electrical issue.
Loose wires from the battery to the engine block and to the starter can also cause issues obviously. You may be getting power to everything but the battery wont be able to provide high enough current to turn the alt on (you'll hear the solenoid click but nothing happens in this case).
more info needed.
Old Feb 25, 2011 | 02:09 AM
I-C5's Avatar
theres a small wire conected to the starter byitself the nuts a 8ml or 5/16 check if ur getting current to it when u crank it to start. does ur pump prime? do all ur lights turn on. Dumb Question but is ur battery charged all the way.
Old Feb 25, 2011 | 03:26 AM
TheZDeWolfe's Avatar
hahah funny you say that about the battery stupid as it is.. i once had that happen to me! Id make sure you check that also!
Old Feb 25, 2011 | 09:02 AM
Camokid09's Avatar
battery is charged
i do still have my VATS
i do hear a click
dont remember if security light is always on or not
ill check it all out again the starter is out im about to put it back in i have been caught up with finishing up the rest of my build.
