Sponsored by: CARiD
Fuel Sender Problem
Old Feb 25, 2011 | 01:18 PM
Qcon's Avatar
Default Fuel Sender Problem
Hi folks,
My fuel pump recently went out so I replaced it with a new pump assembly including a new sender (via the trap door method). The issue that just popped up is that it shows Full when I fill up, then drops as I drive, like it should. But when it gets to about 3/4F, when I start up the gauge goes all the way back to F and stays there so I can no longer tell how much fuel I have left. When I fill up, it resets and works like normal then fails again at about the same place.
I've pulled the assembly a couple times and can't see anywhere the sender could be snagging, but I could be wrong. Any ideas what might be causing this?
Thanks.
Q
Old Feb 25, 2011 | 01:41 PM
O2Form's Avatar
Most likely the sender unit is bad...
