Sponsored by: CARiD
Rear sway bar
Old Feb 22, 2011 | 01:32 PM
duvalsoldier904's Avatar
Default Rear sway bar
Ok so I took my car in today to get an oil change and while the car was up I was talking to the guy about a bumping/ rattling noise I have been hearing when I step on the gas he checked and out and said that the bushings on the rear sway bar were going bad/ already bad and I just need to kno is that something I can fix in my driveway and if so how hard is it to do?
Old Feb 23, 2011 | 10:55 AM
patSS/00's Avatar
Not hard at all, I replaced my rear sway bar in the driveway with rear wheels just up on ramps as I recall. You probably want to replace the endlinks while you're at it.
Old Feb 23, 2011 | 09:30 PM
99FormulaM6r's Avatar
Yeah, you should be fine, as mentioned, replacing the end links would probably be a good idea, never know when they're going to go as well (plus, fresh ones can tighten up the car).
