Sponsored by: CARiD
ses code disappeared after wire mod
Old Mar 9, 2011 | 11:29 PM
SoWazIt2You's Avatar
Default ses code disappeared after wire mod
so weird thing happened today. i did the wire mod by de-pinning the connectors, labeling them, rerouting and reinstalling. i had previously done !egr and !air so i have been throwing the two codes. after all is said and done i turn on my car to make sure everything is a ok and go to check my codes and now i only have p0405. so somehow the air system code (cant remember the code) has deleted itself from my system? i took it for a quick spin around the block checking the codes as i drive (gotta love using torque on my phone) and it never popped back up. is this something i should be worried about?
Old Mar 10, 2011 | 08:48 AM
wssix99's Avatar
Save the manuals!
No. I recall that the PCM will remove very old codes that haven't been triggered in X number of cycles. If you look up the specific code, you should be able to confirm the conditions that its set and removed.
Old Mar 18, 2011 | 08:00 PM
stroked383HSR's Avatar
when doing the wire mod....what are the wires that are re-routed?
what do they go to or power?
Old Mar 19, 2011 | 05:24 AM
Steve Gunn's Avatar
I'll bet you a nickle both your codes will come back.
Old Mar 19, 2011 | 05:28 AM
jsteele90's Avatar
they might be off now but they will come back probably NOW! or next time you start your car
Old Mar 19, 2011 | 06:57 AM
camaro981289's Avatar
Same thing as unplugging the battry i think, they will go away and come back later..only way to get the EGR and AIR code deleted is by tuning it all out.
