Sponsored by: CARiD
ticking on cold start?
Old Mar 10, 2011 | 06:44 PM
99TNA's Avatar
Unhappy ticking on cold start?
so i just purchased a 00 ws6 m6, 116k on the clock, changed the oil to mobil1 syn. 5w-30 with wix filter, now noticing on start tick about 100* warm up theres a slight tick, lifter mayb? bad tune? spark knock?....
Old Mar 10, 2011 | 07:07 PM
O2Form's Avatar
LOL I never heard a LS1 that didn't tick, mine ticks so bad its insane.
Old Mar 10, 2011 | 07:08 PM
bad_408_vert's Avatar
welcome to the family and the tick
its normal.
Old Mar 10, 2011 | 07:12 PM
99TNA's Avatar
YAY! thats a huge weight off my sholders
Old Mar 10, 2011 | 07:29 PM
demarco313's Avatar
Tick Tick Tick away.. Alot of ls1s Sound like a ticking bomb on a cold start
Old Mar 10, 2011 | 09:19 PM
Racer001's Avatar
mine sounds like this too. kinda sounds like a damn diesel. My father had a horrified look and I was like yeah I heard they all sound like this cold lol
Old Mar 10, 2011 | 10:21 PM
The Mighty Texan's Avatar
How bad is it? Mine does a little but not too bad, when i removed the air tube from the manifold on my last spark plug change i found that the gasket had crumbled and gotten stuck in the tube, i cleaned it and got rid of my SES light that i was never able to figure out, however it makes a LOUD ticking now for the first 3 min or so (while the secondary air is working) on a cold start then goes away. I just ordered a new one, if i were you i would check that out.
Old Mar 11, 2011 | 12:03 AM
Fast T's Avatar
Talking
Haha welcome to the tick tick club.Dam near all LS1s tick. you have nothing to worry about bro its all good.
Old Mar 11, 2011 | 06:13 AM
ncsu602's Avatar
Mine ticks, but it's more of the sewing machine noise everyone talks about with cammed cars. 129k
I've got a 2000 Z71, 5.3, with 151k on it. It has the famous cold start knock / piston slap, but only does it for the first 20 seconds the truck is running and it does it worse in the winter. It won't hardly do it at all in the summer. This sounds more like the bottom end is about to come apart. I usually sit in the driveway till it stops and go about my business. Doesn't matter what oil or filter I run, same outcome.
Do a search, it's a very common problem and seems to not affect the life of the engine.
Old Mar 11, 2011 | 06:44 AM
Scoobysnacks's Avatar
Same here with the tick. My buddies call my car ratchet engine Wait till you get the mysterious whinning sound after 2,500 rpms for the first 20 minutes. It'll drive you nuts.
Old Mar 11, 2011 | 06:19 PM
LS1rob00's Avatar
Mine ticks a bit too, this thread made me feel better
Old Mar 11, 2011 | 06:26 PM
- 024mula -'s Avatar
Since were on the subject, What makes the LS1 tick?
Old Mar 12, 2011 | 12:47 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Look, I know you guys are going to think this is a plug for a product, but in ALL SERIOUSNESS, since switching to Castrol Edge, my engine has quieted down SUBSTANTIALLY.
I first tried the stuff in my Escalade, refusing to believe anything was better than Mobil 1, but Wally World was out at the time, so I did the Escalade with it.
Night and day difference, seriously, no joke. I then did Edge with the 01 SS, and man guys, much quieter.
Give it a try. It won't disappoint.
Old Mar 14, 2011 | 06:25 PM
99TNA's Avatar
as would I, veryyyy curious
Old Mar 14, 2011 | 10:48 PM
TurbopigB4C's Avatar
There are various ticking type noises the common ones are from normal valvetrain operation or exhaust leaks.
Old Mar 14, 2011 | 10:54 PM
I know this is LS1tech but the following article on oil seems to make a lot of sense and applies to this subject even though it is from a turbo dsm 4g63 shop. It goes over how all of the modern oils are primarily concerned with gas mileage and emissions and that all of the oil you buy in the normal stores is GF-4 including Mobil 1 which is not an oil for racing engines. http://store.forcedperformance.net/m...otor%20Oil.pdf It also includes a list of good racing oils and how much they should cost.
Old Mar 15, 2011 | 12:04 PM
99TNA's Avatar
so im guessing lucus oil additive would be a bad choice lol
Old Mar 15, 2011 | 12:39 PM
sscamaroburn02's Avatar
I switched from a synthetic oil to conventional castrol 10w-40 and my car got alot quieter. Every so often it will tick a little and fade away. ls1's are known for this. I wouldn't worry to much about it though unless it is excessively loud. good luck.
Old Mar 15, 2011 | 12:44 PM
KevinR's Avatar
The amount of clearance between the piston and the cylinder wall are the primary causes for the cold start "tick/knock"
Old Mar 16, 2011 | 01:58 AM
Piston Slap is another ticking noise even new pistons only sometime fix the problem.
