Sponsored by: CARiD
Thud while after shifting certain gears
Old Mar 25, 2011 | 08:58 PM
Zerokube's Avatar
Default Thud while after shifting certain gears
Seems like something is broken underneath my car. Every time i get on it and in between shifting i feel a thud directly below my drivers seat/console area. Anyone know what that might be? broken tranny mount or trq arm mount or something?
Old Mar 25, 2011 | 09:04 PM
20TA02's Avatar
i have the same problem... mine is the torque arm hitting the body for sure
Old Mar 25, 2011 | 09:12 PM
MasterTomos's Avatar
Sounds like a tranny mount
Old Mar 27, 2011 | 09:24 PM
Zerokube's Avatar
anyone else?
Old Mar 28, 2011 | 10:12 AM
The tranny mount is fairly easy to check, have you done that yet? They're less than $20 and take about 20 minutes to swap out...
Old Mar 28, 2011 | 10:54 AM
Zerokube's Avatar
havent done it yet. when my car was on the lift last, my brother noticed my trq arm bushing was toast as most of the bushings on my car. i guess ill check it when i can find my good jack
Old Mar 28, 2011 | 07:36 PM
99peweterls1's Avatar
my car is doing this also. My torque arm ibushing was bad so i bought a umi torque arm, with bushing. I also upgraded the lower control arms and pan hard bar. Doing this stiffned the car up but now my motor mounts and tranny mount are shot. When you upgrade something the drivetrain finds the next weak link. Be ready for that.
Old Mar 30, 2011 | 04:59 PM
jim ravencraft's Avatar
Hi,
i would put the car on a lift/rack and check things out from the bottom
check trans mount/torque arm and motor mounts. I would also check u-joints........good luck............ Remember you can power brake to check motor mounts..........just recruit a friend......have a blessed week......jim
