Sponsored by: CARiD
wheel bearing
Old Mar 25, 2011 | 09:12 PM
blitzace12's Avatar
Default wheel bearing
on my DD '02 olds intrigue. I replaced a bad wheel bearing. I used the old elbow torque wrench. Now i hear squeeling comming from that side. Did i over torque it? And if i did can i retorque it and be fine?
Old Mar 25, 2011 | 09:13 PM
blitzace12's Avatar
it has only been about 4k miles BTW
Old Mar 26, 2011 | 03:48 PM
wssix99's Avatar
Save the manuals!
No, torque shouldn't matter. Under torquing would be more of an issue only if the thing was falling off.
Are you sure the squeal is the bearing? Maybe a quiet bearing is now exposing a brake problem?
Old Mar 26, 2011 | 04:25 PM
blitzace12's Avatar
changed the brakes. Rotors and pads. Everything was great for a 1000 mile trip. Then after i got home a few days later the squeel started.
Old Mar 26, 2011 | 08:52 PM
jim ravencraft's Avatar
It sounds like an issue with brake sensor or installation problem..please check prior to operating your vehicle. Best of luck and have a blessed week....jim
Old Mar 27, 2011 | 01:29 PM
wssix99's Avatar
Save the manuals!
Could be something simple like lubrication. When does the sound happen. When you are moving, when the brakes are on, when you are speeding up, etc.?
Old Mar 27, 2011 | 08:55 PM
blitzace12's Avatar
It ended up being the backing plate rubbing on the rotor. Simple bending fixed it.
Old Mar 29, 2011 | 07:55 PM
Hi,
i'm glad you found the problem. We often overlook the most obvious things.
However, we learn from each experience in life......wishing you a blessed week...jim
