Sponsored by: CARiD
2001 camaro steering column assembly
Old Apr 1, 2011 | 06:24 PM
LS1aiden's Avatar
Default 2001 camaro steering column assembly
Whats up everybody, i need a lil help with my steering column, i had to replace the turn signal switch and fix my tilt but as i was taking everything apart a few objects fell out and i cant seem to figure out where they go heres a picture of them both and i would really appreciate it if anybody could tell me where they go. The little metal piece i think goes to my ignition lock but im not sure, i would like to put everything back they way i found it. Car is a 2001 Camaro SuperSport, manual transmission.
Attached Thumbnails 2001 camaro steering column assembly-photo0532.jpeg   2001 camaro steering column assembly-photo0534.jpeg   2001 camaro steering column assembly-photo0535.jpeg   2001 camaro steering column assembly-photo0536.jpg
Old Apr 1, 2011 | 07:54 PM
LS1aiden's Avatar
I found out where 1 of the 2 pieces go, the metal one is for the ignition, but i still dont know where the other one goes. any ideas????? i really need to put my column back together before it gets dark.
Old Apr 2, 2011 | 12:13 PM
wssix99's Avatar
Save the manuals!
No idea - but this probably has the answer: http://www.diyfiero.com/dropspot/Jaz...ck_Rebuild.pdf
Old Apr 2, 2011 | 06:21 PM
LS1Z28's Avatar
The black plastic one goes around the studs that hold the column up. You should have two.
Old Apr 6, 2011 | 05:13 PM
LS1aiden's Avatar
Thumbs up
wish i wouldve known that, i already had that guide, i just put it back together and everything seemed to work fine. but now i know thanks.
