90k 98 ls1 car maintenance
Old 05-03-2011, 08:31 PM
Randal McSandal's Avatar
Default 90k 98 ls1 car maintenance
Just picked up a 98 camaro with 90k on it. The car is stock engine wise but has different gears, a stall, and suspension work. It was taken to the track by the previous owner but he hasn't in the last few years and sold it to me this year with only 200 miles driven in 2011.
I plan on changing the engine oil with 5W30 mobile 1
Changing the auto trans fluid with (need recommendation!) & installing a b&m trans cooler.
Lube suspension bushings
The car feels worn, which it obviously is with 90k on it. I'm going to check tomorrow for wiggle in the wheels (tie rod etc) and also plan on replacing the u joints with spicer 5-3147X as they clunk when dropping power.
Just trying to get all maintenance taken care of before I begin to add power
Thanks!
Old 05-04-2011, 12:34 PM
BAT TA's Avatar
Congrats on the purchase, do you know what stall it has? Driving a stalled car without a trans cooler is not good. The stall generates more heat and heat is the number one enemy of your transmission. I'd put that trans cooler on ASAP.
Old 05-04-2011, 12:37 PM
It's a Fuddle 3800 stall. I plan on getting a B&M very soon.. Will I need to have the car on a lift to install it?
Old 05-04-2011, 12:49 PM
BAT TA's Avatar
No the cooler is a pretty easy install. This will give you a good idea of what's involved. http://www.bowlingss.com/Mods/Instal...on%204L60E.mht
Old 05-04-2011, 12:54 PM
Ok, I'm about to order the b&m 70264 for 70 bucks shipped. Sound about right?
Old 05-04-2011, 01:00 PM
BAT TA's Avatar
Yeah, I just ordered that same one about a week ago.
Old 05-04-2011, 01:04 PM
Excellent!
My pinion seal has a small leak (not enough to drip just get wet) so I plan to top off the rear end fluid as well.
