Sponsored by: CARiD
Compression Testing
Old May 8, 2011 | 10:13 AM
LS1121's Avatar
Question Compression Testing
What would be a Normal charge for someone to do a compression test on my motor? I have a 98 Z28. Thank You.
Old May 8, 2011 | 10:38 AM
mark21742's Avatar
For around $30 you can buy the tester and do it yourself...and have the tester in your toolbox for next time
Old May 8, 2011 | 10:43 AM
LS1121's Avatar
yes but what about that plug all the way in the back on the passenger side, I can barely change the plug never mind get that hose in there. LOL
Old May 9, 2011 | 11:48 AM
BCKNBLK's Avatar
pretty easy,, just hold the end strait on the block and the hose acts as a bendable extention,,, hence the plug trick people use to start there plugs into the block in hard to reach areas,,, some use a piece of rubber hose on the end of the plug.
