Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
- Camaro 2010-Present: How to Change Cabin Air Filter
Step by step instructions for do-it-yourself repairs.
- Camaro and Firebird How to Change Cabin Air Filter<br>Step by step instructions for do-it-yourself repairs.
Cabin Air Filter install 4th gen (if anyone cares lol)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
JimMueller - That was an illusion, its not a complete seal but my idea was to keep most of the really loose grass clippings and dirt from getting inside, Ever since i did this install I have definately noticed a decrease of debris getting past the filter. It does work tremedously.
To the others it doesnt get wet at all, it is put in behind the water block so I have never got any water or mildew smell from the filter. Also there has not been any buildup or any decrease in air flow. I am assuming from the performance of the filter so far, it will probably last for a year and possibly even more.
If theres any more questions i'll be on more frequently this week.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Lol I have no clue, just glad it didnt shoot through the AC and into my eye, the crazy thing is I prolly used my AC only 20-30 days throughout that entire time and thats all that got pulled through, If i used it everyday I would have had to change that looooong ago.
Did this and works great! Kills the air volume that comes out of the vents, but I guess that just means I have the filter in there really well. Theres no more dust/dirt coming out of the vents when I turn them on. Thanks for the idea.
#34
Alright question. My second gen eclipse is a daily driver with a similar setup, however the ac has an option to recirculate meaning it draws air from just the cabin. Granted when I pulled the fan it was filled with carpet but the car always smells good.
So can you block it from drawing outside air and just pull air from inside the cabin?
#36
I thought that's what the A/C MAX setting is??? If that's the case, why not just leave it on MAX, rather than go through the trouble of permanently blocking the ability to draw air from outside?
#40
I was getting some leaf noise from the blower motor, so I thought I'd check the custom cabin filter I installed years ago with the above instructions. I didn't realize it had been seven years, I thought perhaps 2-3 years max? I guess I need to do it more frequently; the pleats were basically full of dust and leaves, this is what remained after I tapped it on the ground. They didn't have the STP CAF1851P in stock, so I went with the similar size STP CAF1824P this time.
![](https://i808.photobucket.com/albums/zz9/evcass69/20180826_152951.jpg)
