ls1 overheating.
MOST LIKELY,
You are getting air into your cooling system because a piston is pushing air past a breach in one of your head gaskets and into your cooling system. Thats causing the coolant to boil at lower temps and then get blown out the overflow reservoir.
Now you could be lucky and just need a new radiator cap. Or maybe you have a little pinhole leak somewhere.
Allot of times people drive around with a leaky water pump or pinhole leak somewhere and over time coolant gets pissed out without them knowing. Small leaks and even slow water pump leaks begin to leak after the engine is shut down, so the coolant leaks out when they walk away, and then later when the engine cools down it pulls in air. There's the air pocket in the system now that lowers boiling points. This happens till a certain point is reached, then "bam" you overheat badly one day.
So don't go looking for for a leak somewhere while the engine is running, allot of times it won't show itself until the engine is shut down. When you shut an engine down it gets hotter and pressure in the cooling system rises for about 30 minutes. Thats when some of these little leaks start pissing coolant out.
My suggestion: Go buy a new radiator cap, top off the coolant and make sure there are no air bubbles in the system, and see if it fixes the issue.
If it still happens, put the front end up on ramps, get the engine all the way up to operating temp and turn it off, then spend some time waiting and looking for leaks for about 20 minutes. Or just turn it off and wait 10-15 minutes, then go back and look for leaks.
THEN....you can start spending money on a cooling system pressure test, or a leakdown check to find a bad head gasket.
If you think you might have a blown head gasket.....go get a pressure tester and find out. Guessing only goes so far.
I could kick myself, the solution is spray a water/soap mix around the fittings on the pressure tester to make sure THEY don't leak, giving you a false result
Only do this if it fails, if it doesn't awesome.Get yourself the new cap and cooling pressure tester from autozone all in one shot and report back.
When you replaced the overflow reservoir, did it come with a new tube/hose...?
