seatbelts dont lock
WD-40 is the enemy of your car. I keep some in my toolbox but the simple fact is that the only place this stuff should be use on a car is to loosen rusted bolts. The details are all on WD-40's web site: http://www.wd40.com/faqs/
"WD-40 is the ultimate multi-purpose problem solver. WD-40 cleans/degreases, penetrates to loosen up stuck parts, prevents corrosion and is a light lubricant."
The operative words are that its a "light lubricant" and that its a degreaser. While WD-40 will coat surfaces with a light layer of oil and make squeaking stop, (temporarily) but it will dissolve the beneficial heavier greases on parts made to keep them lasting longer and working safely.
Don't believe anything you read on the internet, though! Try some out on a squeaky door hinge and compare it to other "lubricants." You'll see that using WD-40 on a hinge will make the squeaking much worse when it wears off because it cleans out all the other stuff in the bearing.
If a part is wearing or squeaking, the best thing to do is to do research and find the proper weight and compatible grease (not oil) to fix the problem.
