had 4 codes come up today in the 00 formula. help.
well update on this, i got the piece in and replace it with no problem. drove the car to work and it ran great with no problems. now today i drove it to work, it ran fine there (25 miles one way ). on the way home it started doing the same symptoms as before. it died about 10 times on the way home but always started right back up. it threw the same 3 codes about the crankshaft sensor. i guess now i need to check the wiring from the sensor but idk where it runs to or where it is grounded to to check for a short.
also my battery guage is showing 11 or 12 volts. could my dieing battery be causeing this to happen?
