Sponsored by: CARiD
Coolant Blowing Out Of The Overflow
Old Jul 5, 2011 | 11:01 PM
wssix99's Avatar
Save the manuals!
Originally Posted by blackbirdbrain89
this might sound dumb is the bypass line and the over flow line mixed up.. my buddys car was doing that and that what his issue was
Wow - That's something to definitely check for! OMG.
jetaws6 - So when you bought the car... the thermostat was normal and the needle pointed straight up? And then after your head swap, the needle started hanging around a lower temperature? That seems odd to me - I'd wonder if the coolant sensor might be bad and not triggering the fans to come on.
Old Jul 6, 2011 | 06:46 AM
jetaws6's Avatar
No the needle has always been that low. I thought It was normal until my friend whose got a z28 said his is always straight up and down.
I think I looked at that but I might have looked at the wrong thing. The crossover pipe on the heads is on the top fitting right below the rad cap and the overflow hose is on the one right below that?
Old Jul 6, 2011 | 09:35 AM
JaYZeig's Avatar
Originally Posted by JaYZeig
hhow about when you shut the car off? does coolant come out of the over flow cap?
iirc..i had this problem when the car was turned off and the 2 hoses that go th the fittings on the radiator right below the radiator cap were on backwards...the overflow line goes to the upper fitting, the lower fitting goes to the engine steam pipe.
didnt you check this?
Old Jul 6, 2011 | 09:49 AM
jetaws6's Avatar
How is it supposed to be. Line from the coolant crossover on the heads to the top fitting and the overflow on the bottom?
Old Jul 6, 2011 | 10:39 AM
White_Hawk's Avatar
The coolant temp gauge on the 98's reads different from the 99+ cars - it will only be straight up at 200 or so. If you are running a low temp thermostat, it will always point to 10 or 11 o'clock.
-Geoff
Old Jul 6, 2011 | 11:25 AM
blackbirdbrain89's Avatar
The coolent bypass goes to the lower of the 2 the over flow goes on top. If not every time ur drive it will not keep any psi and will over flow ur tank
Old Jul 6, 2011 | 11:43 AM
jetaws6's Avatar
whats the bypass?
Old Jul 6, 2011 | 06:47 PM
jetaws6's Avatar
This is how mines being run currently
Old Jul 6, 2011 | 11:36 PM
JaYZeig's Avatar
lines look to be hooked up correctly..
Old Jul 7, 2011 | 10:49 AM
jetaws6's Avatar
My 10 bolt blew out the other day. I am going to pick up a t stat and change that while I am waiting for my mwc 9 to come. Is there a test that will show if there is indeed coolant in a cylinder?
Old Jul 7, 2011 | 11:52 AM
Yes. There's a fluid that when is exposed to exhaust gas it Truns from blue to green. U can get it at Napa I think. Its going to be a kit I'll need to get to use it right. U can also fill her up and see if u get any bubbles comeing up. U could also pull ur plugs to see idk they have a white/green hase on them. If so u gota issue
Old Jul 7, 2011 | 11:53 AM
  #32
jetaws6's Avatar
Theres no bubbles I know that for a fact. I guess ill try to find the fluid
Old Jul 8, 2011 | 01:56 PM
  #33
wssix99's Avatar
Save the manuals!
What happens to your temp gauge when the overflow happens? Does it go up? Do your fans go on? I'll bet its your coolant temp sensor or the thermostat that are faulty on you.
Old Jul 8, 2011 | 02:19 PM
  #34
jetaws6's Avatar
the temp goes way up but thats due to the fact that I am extremely low on coolant
Old Jul 9, 2011 | 07:20 AM
  #35
wssix99's Avatar
Save the manuals!
Does it shoot up right away when it starts spitting or before or after?
Old Jul 10, 2011 | 11:02 AM
  #36
jetaws6's Avatar
Im guessing right after. Ill pull over when i see my temp start climbing and I can see coolant in my bay from where it shot out
Old Jul 11, 2011 | 12:24 PM
  #37
wssix99's Avatar
Save the manuals!
If you are sure the head gaskets are good and holding pressure, its more likely that the temperature is rising in conjunction with your pressure spike.
When you pull over, are your radiator fans running? If they aren't kicking on when the system gets hot, that could be the cause of your issue.
Old Jul 11, 2011 | 12:46 PM
  #38
jetaws6's Avatar
Now that I think about it I dont think I have heard the fans on since the swap Ill recheck the plugs tonight or tomorrow
Old Jul 11, 2011 | 02:53 PM
  #39
LS6427's Avatar
I have had this problem for a little bit now and I cant think of the solution. It only happens at wot and it doesnt happen all of the time but when I get on it coolant flys out of the overflow all over that side of the engine bay. I have gone through 3 radiator caps and they seem to fix the problem for a little then they start losing pressure. Could it be coolant in a cylinder even though I am not blowing white smoke and my oil is clean? Or could it be something else?
Do a leakdown check or a coolant system pressure check......
You have a blown head gasket if you ask me. And Yes, sometimes the piston will push air into the cooling system on the upstroke (power stroke) ALLOT more than it gulps coolant on the downstroke. So blowing white smoke is not always present.
If you do the easier/free coolant system pressure check.......you still need to remove all 8 spark plugs in case a cylinder fills with coolant through the blown gasket leak. Make sure you don't start the car with coolant sitting in a cylinder. Turn the3 engine over for a few seconds with the3 plugs still out to get enough out so you don't hydralock the engine and damage internal parts.
Old Jul 11, 2011 | 02:58 PM
  #40
jetaws6's Avatar
If I did a pressure test on the coolant system though and left the spark plugs in and the coolant level stayed the same would that rule out the head gasket or would it still be a possibility?
